Glasswire loses its settings at irregular intervals, then I have to restore the client.conf
Sorry for the issue. It’s unusual for GlassWire to randomly lose settings unless its files are deleted.
Do you use a cleaning type of software? If so can you white list the programdata/glasswire folder?
Please let me know if that does not apply to you and I can suggest another solution.
I use CCleaner only, but not at the moment when Glasswire lost some Settings.
Please reinstall GlassWire’s latest version with the “clean install” option checked, then please white list the programdata/glasswire folder (with CCleaner) to avoid our settings getting deleted in the future.
Sorry for the problem.
but the Settings Directory is:
C:…\AppData\Local\glasswire\client.conf
I don’t use CCleaner, also in the Protocol of them are no GlassWire files
and I want to keep my Firewall Rules so I can’t clean install.
OK, hopefully the issue will not happen again due to the deletion. Sorry for the issue.
To be honest i never ever would put ccleaner on my pc since its bought by a notorious company which has no good reputation.
Its actually by many AV products flagged as Dangerous
