Monitoring a remote PC not on the same local network
Is there a way to monitor a remote PC that is not on the same local network?
@yassin
Yes, but you may need to use some sort of port forwarding, depending on your network.
https://www.glasswire.com/userguide/#Remote_Monitoring
