Hallo,
my pc found not all devices, i use GlassWire 1.2.64b Pro
the Program is great i love it.
under Network
i have
1 PC
1 Smartfone
1 Tablett
1 FritzBox 7490
but only 3 devices are to see
i have cecked the ip adresses, i see my PC Summer not found
Can you help me ?
sorry for my bad english, but i live in Germany
Greetings
MarcusR
Thanks for upgrading GlassWire and sorry for the problem.
Did you reboot GlassWire after installing? If not please do so. GlassWire requires a reboot to pick up all connections and we warn about this, but don’t force it.
Also does your router have a “guest” or some other security mode that separates devices? If so GlassWire can’t see these separate devices. Thanks!
yes the FritzBox 7490 hat Guest Netzwork, but it is diabled
Yes i have do a restart, all devieces were found, but my PC Summer not
i habe checked the ip adresses at end Summer has 209 but
is not found.
Note. but is ok the the Software is verry good i love this pretty Software.
Note 2 i have do a download my internet conection is VDSL 2 50.000
at download with 49.0000 Glaswire says 6.000 what is this ?
Greetings
Are you asking what VDSL is? I think it’s probably a DSL modem or some type (just guessing)? Or maybe I’m misunderstanding. Thanks for your feedback and sorry for any confusion!
