I’ve been using Glaswire for about six months now and just stumbled on a nice feature that I had missed previously. When working with the Graph and Usage tabs, you can select the period to be examined by adjusting the “bubbles” on the bottom timeline. What I had missed is that, if you click between the bubbles (assuming they aren’t expanded to the max), the “active” bar will slide and the graph and table detail adjust dynamically. Much nicer than constantly adjusting the bubbles to highlight the info you want.
Thanks for this. I’ve used this more than once already.
