Restarting my computer and this shows up…
If picture not showing, this is what it sees…
“The application was unable to start correctly (0xo0000005).
Click OK to close the application.”
What to do about this?
Regards MM
Regards MM
Sorry for the issue.
I have never seen this problem before. If you go to add/remove programs and uninstall GlassWire, then reboot, then reinstall GlassWire does it solve it?
