I haven’t installed the product yet but I plan to soon. I use Symantec Endpoint Protection and stumbled upon Glasswire primarily because I was looking for a network monitor.
Is there a way to use Glasswire as a network monitor only or is the firewall portion built in and functioning if the product is running, or can it be disabled? I assume there will be conflict if both firewalls are on at the same time as I’ve seen in other posts which reference other firewalls.
Thanks.
