New user, trying the free version atm. Is there a way to prevent programs from running until given permission?
I’m talking above my paygrade here but don’t I want prevent them from running until I decide they are safe?
Example, I got notified google updater ran but it looks like Glassware let it run without asking me if it’s ok.
I’ve repeatedly tried to stop this program from updating, until I use Chrome. It constantly tries to phone home and annoys me greatly. This isn’t the only program, but it’s the principle. Bad actors should be able to be stopped before they run, correct?
“Click to block” mode, “Ask to connect” mode, or “Block all” mode. “Click to block” mode lets all connections through, but allows you to later block connections you don’t like. “Ask to connect” will alert you before a connection starts and lets you allow or deny the connection, and “Block all” mode should block all network connections on your PC.
you could use a hips/firewall such as spyshelter by Datpol , which has application control, but not just asking for internet access… it asks for permission to run, permission to access protected registry, permission if it wants to take a screenshot… etc
also has the huge advantage of anti keylogger protection built in
Glasswire just prompts/asks for internet access yes/no or blocks an application from accessing the internet in a beautiful interface with amazing logging
I did actually mean, not let programs connect but didn’t word it well.
So I’ve set GW to ‘Ask to Connect’ and taking a look at the tutorial on googleupdate.
I’ve tried to disable that program before and took renaming the actual file to stop it.
So this tutorial might be a improvement.
