Glasswire does not block any traffic.
Firewall on, firewall off, Click to Block, ask to connect, block all, it makes no difference. Everything behaves like Glasswire wasn’t installed. I’m posting this with the firewall on, chrome blocked, and Block All enabled. I’ve done 3 clean installs with no other security software running or installed.
Using Windows 10 with all available updates installed.
Problem began after upgrading to 2.0.84 from a much older version(1.?)
Edit: resolved. Firewall disabled in group policy after windows update and glasswire reinstall. No idea how/why that happened.
