Continuing the discussion from GlassWire 1.1.41 available!:
The minor display issue that I reported in the post “Minor Bug in Glasswire Client Display” Minor Bug in Glasswire Client Display does still exist in the new release. The workaround which is to expand the window to a full screen and then back to window still fixes this display issue.
Yes, this version didn’t have any UI improvements. We’ll fix it with the next release that should be a MAJOR update.
I actually assumed that, but since mine is apparently the only report of this concern, I wanted to be sure you were aware that something “miraculous” had not occurred.
I am emailing you a special version of GlassWire to test to see if it still has this bug. Thanks for following up!
Thanks, much again, but no go. Same issue. If there’s anything else you’d like me to do, just let me know.
