Cannot use Putty for connection on LAN devices (SSH port 22).
Yet tried to enable and disable firewall on item (orange flame) but didn’t solve.
Until 2 days ago it was working. Don’t know what’s happened… no update in the meanwhile.
I’m yet using this (should I try beta?):
If you reinstall .80 from www.glasswire.com and choose the firewall reset option, and “clean” install option does it solve it? Please check.
You can also try the beta if you prefer.
Seems fixed with 2.0.80 with firewall reset option and “clean” install option.
Thanks
