Good day.
I Buy yesterday Glasswire and im one disk with Windows 10 Pro N 64 Bits unistalled Glasswire version 1.2.121 end install new version of Glasswire 2.0 and after installed activate Glasswire.
In this disk all right working fine and firewall of glasswire detect all software used network.
After this i go for another disk of same pc where i have same SO installed and unistall also Glasswire 1.2.121 and install new version and activate this also. But in firewall i not see all software used my network connection.
Have for example ace player streaming and before in version 1.2.121 version of glasswire i block this software if no use this for see stramming. For watch streamming i unblock software.
The problem now is this software are blocked all times and i cannot use ace stream player for watch streamming. Ace player stream and others ace stream files are not listed in firewall of Glasswire.
I go for firewall settings of Windows 10 and dissable firewall and try launck ace stream player but have same problem: software cannot connect for net.
What can i unblovk this software if this are not listed in Glasswire? I turn off glasswire firewall also but got same problem.
I see also Nvidia telemetry and others components of Nvdia are not listed in glasswire firewall and also all are blocked.
Any ideia for fix this?
