Remah
May 26, 2016, 8:58am
#1
I’m assuming that GlassWire makes 1 KB equal to 1,000 B rather than 1,024 B. Am I correct?
Do you round or truncate to when you convert B to KB, KB to MB, etc?
I’m asking because a number of times I’ve compared GlassWire stats with measurements from other sources. They didn’t match when rounded to the same precision as GlassWire. The GlassWire stats were often a little bit lower which might be explained if GlassWire either a) truncated or b) converts 1024 B to a KB.
smrs
May 26, 2016, 9:23am
#2
no, 1 KB = 1024 B. If you found other - it’s a bug.
It should round, if it truncates somewhere - it’s a bug.
Remah
May 26, 2016, 9:55am
#3
Actually, I should have added “ps” (per second) because I am asking about bandwidth:
So how many bps in 1 Kbps for GlassWire - 1,000 or 1,024?
It looks like this area of network monitoring is a bit of a mess because there is more than one standard being used by different programs.
The SI standard is for data rates is 1,000 and this is used by many bandwidth monitoring programs, speed tests and ISPs, e.g.
By default, Speedtest.net measures your connection speed in Mbps, meaning Megabits Per Second. Mbps is the ISP industry-standard, and we use it on Speedtest.net so you can easily compare your resul...
http://www.dslreports.com/faq/14472
Having said that other programs are reporting 1,024, e.g.
http://www.dslreports.com/faq/3758
smrs
May 26, 2016, 9:58am
#4
Still 1024, or it will be very confusing since traffic speed
and traffic amount
are very mixed in GlassWire UI
Remah
May 26, 2016, 10:58am
#5
Anyway, that explains the differences between some of the stats from other programs which was my original question.
