I am using release 2.2.268 and remotes are Windows 10 Pro 64bit PCs. If I don’t enter in an IP address restriction; it works fine. If I enter a IP address of a previously working PC; I can not connect remotely. This is because the restriction IP address is not retained/saved by the monitored/server PC. If I return to the previously screen that I used to set restricted IP address; it is blank, i.e. no IP address shown. Help!
Regards,
Speedy
