need reversion #'s added to the installer name. not just the # on the download page but on the .exe it self.
Thanks for your feedback.
Where exactly should the version number be? Can you give an example of another application and how it shows the version number in the way you are talking about? I want to be sure I understand.
I think he means is that if you download the Programm it is called
GlassWireSetup
However having it something like
GlassWireSetupv1.41b
would be easier to identify it once downloaded and having multiple GlassWireSetups in your download folder
Example of a Programm that does that would be i.e. FileZilla
yes that’s what I meant.
