I noticed there is no save option to save history setings, so once you have selected “keep last week” or “keep last day”, after you select clear, then ok, then come out of settings, then go back into settings, it resets back to “all”.
That is correct. You must changed the pull-down menu to choose different options every time. Maybe we’ll consider changing it where GlassWire remembers the last setting of the pull-down menu.
i would think its quite logical to change it to that…some of us might acidentally press clear all, without realizing it resets to “all”…then all the history is gone…options to back up history too incase of accidents, would also help…
