Not sure if anyone else has encountered this issue.
There seems to be an issue with the setting “Ask To Connect”
I am seeing the notifications that the applications are connecting, yet I check their status within the Firewall tab and it shows them as blocked. It simply is not asking me if I would prefer to allow or not. Just blocking by default.
This is really my fault. Apparently the issue was there due to me not rebooting after the upgrade. After reboot the prompts for allowing or not are popping up.
All I really see in the logs is my own unblocking… unless you guys spy something:
I’m glad it’s working. We will still investigate and try to reproduce though, because I think Ask to connect should work even without a reboot. It does for me anyway…
