Hi, I find some issues in glasswire 1.2.64b, so I make this topic for theme
1- some times glasswire show nothing(upload/download)
the problem was solved after re-starting its service
2-glasswire can’t detect all local traffic
in my case glasswire can’t detect adb(android device bridge) traffic
3-glasswire show wrong traffic in usage tab(always show much more)
Could you uninstall GlassWire, reboot, then reinstall our latest version using the “clean” option and see if these problems continue?
Also are you using a third party security software that could be disabling our service?
My installed version is 1.2.64b
Do you released a new version?
“Also are you using a third party security software that could be disabling our service?”: no
Our 1.2 version is a major upgrade, so an uninstall, reboot, and choosing the “clean install” in the installer will usually solve any lingering problems with older versions. If you never used any older versions then this problem doesn’t apply to you.
Do you use Bittorrent?
It’s done, but issues not solved…
“Do you use Bittorrent?”: no
The gw1.2 is my first installation of glasswire
You said you restarted the Glasswire service, but did you reboot your machine. That is recommended by Glasswire.
I reboot my pc after first install. but sometimes glasswire show nothing in graph(zero for uploading/downloading)
