well i don’t have this problem now
but i think your problem cause might be the applications aftermaths
the solution is simple you have to delete all the aftermaths folder and restart it and install the latest version and that’s it
there will be no problem afterwards and if there is
paste your event log here
Had no problem (running 1.0.43.903b) until another app installed VC Runtimes 11.0.61030.0, both x64 and x86. Started crashing almost immediately within moments of starting it. Don’t know whether this was the cause, but it looked possible. Anyway, installed latest (1.1.7.954b) and no problem.
Hope this helps developers get a fix on this, though they may already have done so.
I hate it when apps insist on installing vcredist64/vcredist86 without even checking whether they’re already installed or not. In this case that version wasn’t installed, but in most cases the versions installing are already there.
