Hi, I am a new WG user so bear with me as I am not very computer savy either. I keep getting alerts that something listed as “Microsoft ISATAP adapter” is being added and then removed repeatedly from my computer. Each day since I installed WG, I see it happening several times a day. I looked up ISATAP and found out it could be removed safely and that I should remove any extra copies of it, which I did using my control panel, but it keeps coming back. Is there a way to stop it from loading or should I even be worried.
I started using WG because of problems I have been having with very slow page loading with Google Chrome. I have been using the firewall to block different programs to see if they are causing the problem but still I have to wait for up to 10 minutes for some pages to load like a search results page or sites I have been to repeatedly. I have done several malware scans with Malwarebytes, Windows Malicious software removal, CC cleaner, and Avast, which have found nothing. When I check the WG firewall screen, I have noticed that both Google chrome and Windows Host services are listed as the top users of my bandwidth with both showing up to 900 B/s or even K/s of useage at times. They also show other hosts running through or with them, sometimes up to 20.
Since I cannot firewall block them and still use my computer, what should I do to keep these two processes from hogging my computer and slowing it down? I have Windows 7 on a three year old Toshiba satellite laptop.
