Running Windows 7 Pro 64 bit. GW 1.2.74 Pro.
I have ticked Run on Startup, but the program does not start after a reboot. I checked settings and the tick box is blank.
Do you use any third party utilities that “speed up” your PC? Some of these will disable startup items.
No, nothing like that. I ran CCleaner and checked out the Startup list and Glasswire is there. Worried that something is actively trying to turn it off.
This remains unresolved. Run on Startup tick box is cleared after reboot.
Please try doing a “clean” install and see if it continues. We cannot recreate this.
