glasswire is reinstalled
I started all my applications, check in this evening if the problem exist again and notice the results here
thanks for your help
the system runs over 24hours without problems.
glasswire works fine.
I don’t know what was the problem.
thanks for the nice programm and the quick help
the thread can be closed
I’ve noticed something similar. After running fine for a while, my connection drops and I have to uninstall Glasswire. I didn’t test thoroughly, but just disabling Glasswire didn’t seem to help. After uninstalling everything went back to normal. The PC with Glasswire serves as an HTPC and central downloading hub, so it’s possible that it does have to do with the number of connections, but I can’t be sure.
