I’m having trouble understanding the network usage. For instance, I’ll have 80mb of network activity at a point in time but my DSL only handles 13 mega bits per second. How does this work?
Please check out this guide.
https://blog.glasswire.com/2016/05/09/understanding-glasswires-graph-and-scaling-how-much-data-are-you-using-on-your-pc/
If you do a speedtest at http://openspeedtest.com what does it say your maximum speed is? You may not want to do this if you are a metered data plan of course.
Thx for the quick response. Speedtest shows 15MB upload.
The link really helped. The number I was looking for-bandwdith-is right there in the lower left corner.
Thanks much!
