Hello.
Great application.
I have two complains, though.
The first one: the unit displayed is the wrong one. It shows unit as Kilobits/seconds but what you show is in fact KiloBytes/seconds. Just a mix-up on your side I’m sure.
The ability to config the unit would be great, by the way.
Kristoffer,
the Apps and Traffic views only show you the amount of data downloaded in the time span of 5 minutes/3 hours/24 hours/week (selectable in the top right corner). Currently, there is no way of checking the actual transfer rate measured in KiloBytes or MegaBytes per second.
Thanks for your answer. What is your release planning?
As it is still in beta, it would be cool if we had frequent releases fixing few things each times.
As you use a Windows API (AFAIK), maybe the locale of the OS is important. In French, there is no bytes (B) but “octet” (it is the same thing nowadays), so maybe your app does not found the bytes and fallback on bits.
