Hi: I’ve activated GlassWire and under settings unlocked it
but it goes back to the same “unlock” screen after closing
doesn’t stay unlocked
Thanks for purchasing GlassWire!
The lock is just a setting that allows you to secure your settings with your Windows admin password. That way a stranger can’t get on your PC and change your GlassWire settings without your knowledge.
If you don’t like that you can go to our top left menu and choose “settings”, then disable it.
Be sure and press “OK” when changing the setting.
Thank You Ken_GlassWire That took care of it.
