May I ask a quick question about v2.0.80? If one unlocks Settings/Security & Settings/VirusTotal so that the relevant options are selectable, is it normal that when has exited Settings by clicking OK, when one next goes into Settings the same pages are once again showing as Locked?
Just wanted to check if this is a safety feature rather than what might appear to be a bug. I suspect the former but for the sake of clarity thought it best to ask the more learned of the Glasswire Forum.
2 things happened at 1 timeā¦Very confusing.
Windows update and your updateā¦
All of a sudden my system monitor said I was using 30+% ALL THE TIMEā¦
Did a little looking and found Win firewall connected to Coremessaging, then RPCā¦
TRIED fix/find/ do something, but Win-HOME SUCKS on trying to self fix.
Went to windows help and they TRIEDā¦and DIEDā¦(CANNED ASSISTANCE SUCKS)
Di a couple more searches and found a fixā¦START DEFENDER AND FIREWALL, and hit DEFAULT ON FIREWALLā¦RESETā¦TURN IT ALL OFF AGAIN, and RESETā¦
NOWā¦
Are you using DEFENDER FIREWALL???
Because NOW, Connecting local service, Connection failed, Service STOPPEDā¦
You said windows update and our update happened at one time? We have not alerted any 1.0 users to upgrade to 2.0 yet, and GlassWire has no ability to do an update itself so Iām not sure how it is possible.
Did you install our update in the moment the Windows update happened?
If you are having problems related to our firewall you can uninstall GlassWire in add/remove programs, then go to the Windows Firewall control panel, then choose ārestore defaultsā. You can then reinstall GlassWire using its clean install option. We use the Windows Firewall API, thatās correct.
I received a notice to update from your program.
It failed to install, while the Ver.1 was Running, so I killed the running version, then Ran 2,0,80ā¦It installed then the problem startedā¦
If this is running defender Firewall, Why do we need yours? Bells and whistles??
Im sorry, I dislike windows in the first placeā¦Im old hat and been using comps since the 70āsā¦ SEEN better and USED betterā¦ Only reason I use Win/tel is the games I likeā¦and if they would revert BACK to how they USED to program the gamesā¦I would jump ship FAST.
If you folks are only creating bells and whistles, Iād rather gopt Majorgeeks and pick one upā¦With a Background and history.
I got your private message and replied. No, you donāt have to buy a new one and this is pinned at the top of the forum for 1.0 users that GlassWire 2 is a free upgrade.
@Ken_GlassWire is there any way where we can backup a profile and use it in other systems? I could not find anything conspicuous. Is it the client.conf file?
If you move the config file to your desktop, then quit GlassWire and its service, then add the required Nord line, then drag it back and restart GlassWire and its service, it does not work? I still see this config file for the beta so perhaps Iām misunderstanding something?
Hello Ken, Thanks for the reply but I donāt know what you mean by that.
"If you use C:\ProgramData\GlassWire\service\glasswire.conf does it work?"
Do I have to ad some code or something?
If I open the glassire conf. it says:
db_file_path=C:\ProgramData\Glasswire\service\glasswire.db
geoip_db_path=C:\ProgramData\Glasswire\service\GeoLite2.mmdb
storage_path=C:\ProgramData\Glasswire\service\storage.db
hostname_storage_time=21600
hostname_enable_nslookup=true
