In the “Usage” screen, the “Hosts” are sorted by decreasing volume.
If you click on “More”, this is no longer the case.
I discovered by chance that if you click on the right corner of the window that opens when you click on “More” it is possible to intervene on the sorting order.
There is no symbol indicating that this feature is available.
A symbol should be visible to indicate the availability of this feature.
Thanks for your feedback on improving the usability of GlassWire.
