I bought Glasswire from steam and I was wondering if it’s safe to use it all the time with different computers. Is my separate steam logins considered as one user or will it abruptly end Glasswire use once it reach the threshold?
If you keep GlassWire within Steam, it should work like most Steam games. If you run into an issue email us or message me here.
If you use it outside Steam then it reverts to our rules as shown on our order page.
https://www.glasswire.com/buy/
When moving the code between PCs please go to the top left menu and choose “deactivate” to release the license both on Steam and your regular non-Steam usage if you can.
Personally I would recommend just exporting your key, and downloading the software from the website. Steam causes issues IMO
