It seems that the people of GlassWire have a keen sense of vision, or are using low resolution monitors. Please add the ability to adjust font size, please! I be damned if I am gonna dig out the reading glasses or whatever for very long… this so far is my only problem with the programs, runs fine, no conflicts, doesn’t even get close to taxing any resources… as far as i can see!!! See?
Actually i am using Asus ROG Swift PG278Q that has native resolution of 2560 x 1440
and my font size is normal . there is no issue of font on my computer .
so what i am thinking is you are not using your native resolution
and if you are using your native resolution can u plz tell us your monitor details and operating system
This problem only seems to happen for Windows 7 users. The system we use for our user interface solves this problem for Windows 8 and 10 users, and hopefully they will add a fix for Windows 7 users soon. Upgrading to Windows 10 should solve the problem.
