Hey there,
I’m new here
I found an issue and I like to report it.
When I start my VPN and check the use the same proxy server for all protocols in LAN settings every blocked application via glass wire can reach the internet and get updates.
This issue doesn’t appear if that application wants to get some automatic update.
Only happen when I press the update button so the firewall dont even try to block the update!
Also if I uncheck the use the same proxy server for all protocols the problem will disappear.
VPN: PsiphoN
Example: Pot player
Any idea?
Thnx in advanced.
sorry I was busy
No, they don’t the win firewall is enabled as I said it’s about VPN.
I guess with those settings all of the network connections go through vpn and glass wire can’t monitor them…
Also, there is no separate rule for Pot player into the firewall the only rule for pot created by glass wire and its block.
