Where can I see how many times I've used my activation code (Glasswire Elite)?
Hi,
Where can I see how many times I’ve used my activation code (Glasswire Elite)?
Thanks!
@titaniumapple
You can’t see how many times you have used your code.
However, GlassWire 2.0 codes use kind of a “smart” system to check the activation codes. If you’re using a 2.0 code it’s unlikely you’ll have activation issues.
Email us or message me if you find an issue so I can help you.
