Please try turning on network discovery if you feel comfortable doing so, and see if it solves it.
***Hey @peterhat ***
I had the same problem but I figured it out by myself. You just go to Glasswire Tab, you can find it at the top left and then click on it, go to Setting > then Security Tab > and click on UNLOCK button and at the right side pane, there are two TAB… You should check the first box that says Notify me if any device joined me or quit my local network then lock again by clicking on lock button and voila… This all might help you…Your problem is solved
Hey @peterhat
To connect the wi-fi use this:
- Go through the home button and press the app button
- Make sure whether your Wi-Fi is turned on
- Wait for few seconds, as a device take time to detect network network
