Hi I have been using glasswire for a long time and everything was fine. I have a problem: the firewall does not block and applications connect happily even if they are blocked. I did a clean installation and the problem persists. It’s probably been a long time but I’ve noticed it until today. Does anyone have a similar problem. Thank you in advance for any feedback.
The ALL block does not work either
Sorry for the issue! That’s not good. Does this forum post solve the issue for you? Please check.
Could you post a screenshot of a blocked application receiving traffic - all glasswire effectively does is create rules for the Windows firewall to use to accept or deny traffic - Glasswirre itself does not filter traffic out to my knowledge.
I have already solved the problem. It was a VPN service. I changed the network driver for the VPN service from TAP to TUN / beta /. Not everything works properly again and glasswire blocks it.Thanks all
