how im set up
modem to router
router to switch (unmanaged)
switch to house
house a server that is plugged directly into that hib with glasswire on that server
On the network tab you see my mobile devices ( well I should say you see 1 of my mobile devices even though both are exactly identical)
You also see my other wireless devices.
I have a media server installed on that server as well.
when I run the media server via my TV i see usage on the TV’s IP go up when i use remote connection software from my laptop to the server I see my usage go up. when i stream a YouTube video i see my usage go out regardless of where it is used that is to say EXCEPT my mobile devices.
So despite glasswire seeing that IP as a network device it does not have the ability to see ANY usage off of that IP address.
This REALLY defeats the purpose of such a program. Also really defeats it in that glasswire picks and chooses what devices it will display.
Suggestions:
even if you need to install a server connector on your mobile devices ect this would be acceptable.
rename network devices under the network tab
