Glasswire Service did not stop propper. Neither it works in 1.1.7 nor in 1.1.15. Win 8.1, 64 bit.
When you say did not stop propper what do you mean exactly? Do you mean when force quitting it or during install?
I mean, it is impossible to stop the Service via servicecontrol. Closing the gui works^^
I think this is the same Problem why the update didn’t worked proper. The Service did not stop so it cant be replaced.
Thanks. We will try and recreate and fix this problem.
