I had this problem with 1.2.5x & 1.2.6x where my system slows to a crawl a few minutes after installing. Only uninstalling and rebooting remedies the problem. Also, each time it happens it leaves a dump on my desktop… (wait for it…)
In previous posts the solution was just to update. Should I just wait for the next release?
TIA
Do you use Nahimic audio software? If not can you email us the dump using a cloud service?
If you’re using Nahimic please update to their latest version.
Nope, forgot to mention that I don’t use that software. I’ll upload the dump to the cloud.
Hey, any updates??? Anything?
Could you reply to the email you sent if you’re still having the issue with the latest update?
Please download GlassWire from www.glasswire.com and do a “clean” install and see if that solves it. Sorry about the problem.
