IMAGE REMOVED BY ADMIN - PARTIALLY SHOWS ACTIVATION CODE
i wasn’t using the app for a while,now that i tried to install the latest version i can’t activate it.
Please try again now. Also please be sure you have not blocked GlassWire itself from accessing the network. Thanks!
When moving the code between PCs or reinstalling the OS go to the top left GlassWire menu and choose “Deactivate” when possible, but we’re always available to reset codes that have any problems.
issue solved, thank you
I run GlasWire behind a proxy server to access the internet, how I can grant GlassWire the access over that proxy for activation ?
I deleted your screenshot because I noticed you could kind of make out your activation code. If you run into a problem again due to someone using your code let me know and I’ll make a completely new code.
