If there is a way to initiate a remote connection to another machine running the software, can you / will you all considering running that as a service so that I can have it work on, say, a Raspberry Pi or integrate it into an Access Point from a manufacturer, so that I can use that as I remote monitor for a customers network?
I am in to test, help, deploy, beta, etc. Lemme know. This would be insanity.
If Glasswire is installed on a pc, then with “Remote Monitoring”, I an push alerts out to a central monitoring pc. And if Glasswire is on all my pc’s at work, they can all send alerts back to my pc.
Well phase one is collecting the data. Phase 2 is how to sift the useful from the noise.
