Hi
I like GW and hoping you guys can help me complete the security I need for myself and employee, what can I use that will do the ask to connect on my Android and a iphone?
Thank you
Hi
Thank you
We are actively working on this for Android. We hope to support iPhone someday. Thanks for using GlassWire.
We have an Android app here https://play.google.com/store/apps/details?id=com.glasswire.android and I think he wants something similar for iPhone.
Thank you for the info. Appreciated
The USB cable can be used to connect Android and iPhone i often use it to connect Android and iphone for data transfer ,
I was also facing this same problem. But the issue was solved by my friend
I do not think that gw is still available for iOS but I am eagerly waiting for it.
