Hi,
Struggling with multiple issues where Bitwarden password manager (Android) is unable to connect to it’s remote server.
Unable to synch or save data…
Disabling the Glasswrire firewall control is the only way to ensure connections. Simply allowing Bitwarden fails…
Check your support email for feedback…
Continued investigation into this issue, reveals the issue is based on the IPv6 configuration in Glasswire as it actually blocks some applications such as the Android version of Bitwarden app…
Disabling IPv6 resolves it.
I will attempt to inform my clients further on related issues associated with this interesting problem.
This should not cause too much trouble as most are still using IPv4 as base protocol, however this is troublesome for support nerds like me as it’s not always immediately apparent what the issues is behind the scene…
