ive been trying to get glasswire to work on my computer for a few days, and have no luck.
it installs as normal, fires up, and i get
''an error occured. contact glasswire for help.
i try restarting, i try to press connect, i get the message
‘‘the glasswire service has stopped working’’
i havent gotten it to work at all, with clean installs, disabling my firewall, restarting the computer, voodoo and ritual sacrifice of a goat. nothing seems to work
I ask because if your WLAN AutoConfig service is disabled, it can sometimes cause GlassWire not to run. This service is on by default with most PCs, unless you manually disabled it.
If you did so, can you re-enable it? Then GlassWire can run.
