Can't use Android Auto
Recently discovered Glasswire and really like it. However, I can’t seem to use android auto while it’s running. Is there any way to allow android auto to get through the vpn? Thanks for your help.
@bubble Thanks for reporting this. Would you mind sending an email to our support team help@glasswire.com so they can help look into this?
sure, will do. Thanks
Android Auto absolutely hates some VPNs lol. Split tunneling usually fixes it, just exclude Android Auto and Google Play Services from the VPN. Otherwise it keeps freaking out and refuses to connect.
