Hi,
just bought the Elite version for my network. What I am missing (after two hrs use) is a kind of console to centrally manage all PCs. I.e. I want to have ONE spot to check what is going on in the LAN.
Any plans on this ? Or is it hidden somewhere and the newbie didn’t find it?
Thanks for reading
J-Co
Thank you for upgrading. Yes, you can set up a central way to manage your PCs https://www.glasswire.com/userguide/#Remote_Monitoring.
