I mainly just use the “Traffic Monitor” feature and so when I open Glasswire, I want it to open to that screen if possible. Currently it always opens to the “Glasswire Protect” screen which is not the best experience because I always have to switch to the screen I want (which is Traffic Monitor).
So what I’m asking for is a new setting which lets users decide which screen glasswire opens up to. What do you guys think about that?
Hi haso
The Traffic Monitor tab will always open on that, but when you reboot, yes it defaults to Glasswire Protect. Not sure if the GW team would change this behavior . You could send email to help@glasswire.com and see what they think
I had faced this before.
I’m sure it used to remember and redisplay your last viewed screen.
This must have changed in a recent update.
It does still remember if the Monitor was last used in Graph, Usage, or Map mode. So hopefully just a bug/oversight.
Hi ittroll
Not sure about others but on 2 of my window boxes,
my above comment still applies.
I did retry what you mentioned just to see what would happen, but it still reverts back on reboot to Glasswire Protect tab.
Mine is the same. After reboot or an app restart it reverts to the Protect tab. However, it does still remember which of the 3 Monitor screens I last used when I switch back to Monitor. So it half remembers.
