This morning I bought 10GB of data to use on a USB Data Stick thru a 3G connection to authenticate some games ( my PC is AirGapped) I had WireShark ticking along but after a Total 186.8MB I was informed that I need to purchase more. Does this Total All Data Usage In and Out not = what the PC actually uses between it and the outside?
Nothing else connected.
WireShark was FlatLined before and after data usage /
Still dont trust windows dirtbags, / using Win 7 64bit (so my PC tells me)
side note to WS tech, I noticed under “inactive apps” it doesn’t recognize double ups when a program is reinstalled, it just adds it next to the last install. . I have GTA5 launcher listed a dozen or so times. Its Hording! maybe thats the solution above, multiple decuplicates for one program maybe counted as one?, piggy backing?
