Do I have the ability in the app to monitor all my apps to alert if one starts using an excessive amount of bandwidth? I had a podcast app last month that did not abide by the “only download on wifi” setting and blew through our data. If I had had an alert to say hey this has used 1GB of data in the last hour, I would’ve caught it sooner and killed it.
Not specifically but if you go in the settings you can enable the Data Plan. You can set usage notification for Day, Week and Months. On top of that when you go to the Usage Tab, you can list by apps and see exactly what is using what percentage of the Data. This will also allow you to categorize either Day’s, Week’s or Months.
