Is there an ability to exclude a folder (and all its contents) from being blocked by the firewall if I have ask to connect on? If not, is this something you’d consider adding?
Thanks for your feedback. I’m not sure if it’s technically possible but our team reviews all feature requests.
Any word on if this is something you’re willing/able to do? Stuff like Easy Anti Cheat always has issues with it, as when on ask to connect, the prompt to say yes tends to take too long to pop up, which errors out EAC. So I end up having to turn the firewall off for games with it in it.
Switching to Click to Block sometimes causes issues, so turning it off tends to be easier.
Thanks for your feedback. I’ll share your use-case with our team.
