Hi. I just upgraded to 1.2.64b and can no longer access my 3 other computers. When i switch back to the old version it works. I uninstalled the old version, restarted my PC and installed the new version with option ‘clean install’ but still its not connecting. Any help?
Do you mean you can’t access your 3 computers with GlassWire’s remote monitoring feature? If so you need to update all those PCs with GlassWire’s latest update, then it should work with no problems.
We had to change how GlassWire’s graph worked to decrease resource usage and this change requires remote PCs use the new update also.
Thats exactly what i meant Ken. I have updated the remote PCs as well and it worked well. Thanks hey
