A Very Good Day to Everyone,
I hope everything is going great.
I just bought the Pro version of Glasswire and installed it on 2 pc
Glasswire worked on the first PC.
Glasswire did not work on the second PC.
I am trying to use the “Click to Block” Feature on the Firewall TAB
I found out that when Glasswire creates the Windows “Inbound and Outbound Rules” at the Windows Firewall Level, when I do a “Click to Block” on a particular application, the Path for the application is set “Wrongly”
For example, instead of having a path of : c:\Program Files\Remote Admin 3.0\Radmin.exe
I am not sure why, Glasswire set the path to : i:\Program Files\Remote Admin 3.0\Radmin.exe
This is evident for all the application inbound and outbound rules in the Windows Firewall Rules Applet
Because the Path is set wrongly, the application is not blocked as intended because the inbound and outbound rules created points to the wrong path to the application
If I open the Windows Task Manager and view the properties of Radmin.exe, the path to Radmin.exe is set and shown correctly … which is C:\Program Files\Radmin 3.0\Radmin.exe
This means that Windows itself knows the “Correct Path” for Radmin.exe
I have tried a few other applications such as TeamViewer and it too has a path set wrongly to the i:\ drive
So can someone please help me out on this issue ?
THANKS !!!
