Firewall, when ever will it be fixed?
I’ve had it with this stupidity.
Where is the RULES editing? Why isn’t it a simple search or even a Sort? Not even a “ballon” when hovering over a program name…
(Snaps from Windows firewall minutes ago.)
Oh, and here#s from within GW. Had to dig through tens of pages of “inactive apps” and Block all of them to get in something resembling a sorted list. Something that should have been from the start!
Also give us an Easy, quick way to MASS remove!
I want to know how do you block a program that is part of a group without blocking the entire group?
Fix the firewall options!
ONE Month later!
CLEAN install. SAME CRAP with Blizzard and Dropbox! FIX IT!:pensive:
How hard can it be
I’m unable to reproduce this problem. I use Dropbox but not Blizzard.
Please uninstall GlassWire, then go to the Windows Firewall control panel and choose “restore defaults” then reboot, then reinstall GlassWire using its “clean” install option.
