Could it be possible to enable dark mode on the forum (I know discourse has it built-in ^^).
Would be a great thing to have (my eyes would finally stop bleeding when reading the forum :P)
Thank you
Thank you
Can you check your settings and see if it’s working? I think I set it up, but I am not 100% sure.
Working like a charm, thank you !
(Don’t see it in the settings though. but it’s active)
If you go to your preferences/interface are you able to change it? I made the default white again, but now you should be able to change it?
Nop not showing up as it should.
OK, I will try to figure it out. I went to the official Discourse site but the options they show there don’t seem to exist anymore for some reason. I think they changed the UI?
I am having trouble setting it up as they give instructions to since those options don’t seem to exist anymore.
I did not install discourse since a long time.
Just know form another site that installed recently that the option is there, but no idea exactly where for now
Just coming back on this as it is still not active for us to use…
(My eyes are crying and asking for dark mode every time I read the forum…)
